Mallory Smith Posted on Nov 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Quadratic formula Quadratic Motion Problems - helicopter plans to release a bucket of water on a forest fire- water drops with an initial velocity of 2 feet per second from a height of 500 feet- write an equation that models the height of the water with respect to the time after it is released- Question I have: Do I use -16t squared for the time or -4.9t squared?
Square Footage
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 11, 2019
Square Footage
Contributor
Level 1:
Answers
Questions
0
Helped
115
Points
You should use -4.9t squared for sure
for details please refer to Quadratic formula calculator
https://quadraticformulacalculator.net/calculator/quadratic-equation-solver/
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Office Equip... Master 102,366 Answers
  • Posted on Nov 12, 2013
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428445
Points
622693
The answer is yes.
The acceleration due to gravity is approximately 32 feet per second or 9.8 meters per second. If you're measuring the distance in feet use 16, if you're measuring in meters then use 4.9.
4 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jan 19, 2009
SOURCE: Re: Quadratic equation
I like to take the a, b, and c values and store them as variables  -  a->x b->y c->z
then run: (- y + SQRT ( y^2-(4xz) ) )/2x     AND  (- y - SQRT ( y^2-(4xz) ) )/2x
the parentheses may be a bit confusing - 1 holds the whole top of the formula to be divided together, one holds everything under the square root, one holds the -4ac (or -4xz).
That ought to cover it.
Anonymous
  • Posted on Apr 04, 2009
SOURCE: My Ti-89 won't factor a quadratic equation with imaginary roots.
(a-b)3
k24674
  • 8093 Answers
  • Posted on Oct 02, 2009
SOURCE: want to solve quadratic equations on my casio 3650p super fx
In your manual, Appendix Program Library, (Page A1) you have the listing of the problem to solve the quadratic equation. Type it in your calculator and execute it.
Hope it helps.
k24674
  • 8093 Answers
  • Posted on Aug 21, 2010
SOURCE: how do i enter the equation 5x-3=11+12x
The variables you have at your disposal in this calculator are
A, B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key before the key near which is written the name of the variable. You will notice that the markings of the symbols accessed with the [ALPHA] key are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The other = sign is marked on the body of the calculator with the same color as the [ALPHA] key. It is located at the top left of the keyboard (excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 (not your expression)
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually when you enter such an expression it is with the intention of solving it for X. By default X is taken to be the UNKNOWN. You will be prompted to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So, if you want to use the Solve function, you press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Then you will be prompted for any other non-X letter.
How am i supposed to solve a quadratic equation ?
Use the quadratic formula, or factor the quadratic polynomial. Once factored into a product of two first degree binomials, the roots are obtained by setting (in TURN) each binomial factor equal to zero.
1helpful
How to solve quadratic equations on fx82ms calculator
You can do it the same way people did it before calculators were invented. Just use the quadratic formula: http://en.wikipedia.org/wiki/Quadratic_formula. Some sophisticated calculators have generalized equation solvers that can handle equations much more complicated than the quadratic, but the fx-82 isn't one of them.
How to solve quadratic equatons on fx82ms
Quadratic equation fx-82ms
You can do it the same way people did it before calculators were invented. Just use the quadratic formula: http://en.wikipedia.org/wiki/Quadratic_formula, and let the calculator handle the arithmetic. Some sophisticated calculators have generalized equation solvers that can handle equations much more complicated than the quadratic, but the fx-82 isn't one of them.
8helpful
How can i solve quadratic equation (aX^2+bX+c=0) with my BA II plus texas instrument calculator?
The BAIIPlus doesn't have anything specifically for solving quadratic equations. You can simply plug the coefficients a, b, and c into the quadratic formula.
3helpful
How do i factor
This calculator is unable to factor a polynomial expression.
In general there are a few factoring methods
  1. Factor by grouping terms
  2. Factor by completing the square (quadratic polynomial)
  3. Factor by finding two integers such their sum is equal to the coefficient of the middle term, and their product is equal to the third (constant term). This is valid for a quadratic polynomial where the leading coefficient (of the x^2 term) is equal to 1. X^2+SX+P
A cubic equation can be solved algebraically, although two solutions may be complex. Use the Cardano formulas. A quartic equation can be solved by the formulas for the quadratic equation, if you transform the quartic equation to look like A(X^2)^2 + B(X^2) +C=0
3helpful
How do you do quadratic equation
If your equation is ax^2 + bx + c = 0 then the quadratic equation is 3ea647783b5121989cd87ca3bb558916.png. Just plug the corresponding numbers into the formula and you will get the answers.
2answers
How to program the calculator TI-nspire to solve the quadratic formula
Whay would you want to go through the hassle of writing a program to solve to solve a quadratic equation`The calculator has two buit-in command to do just that. It has Solve and cSolve (for complex solutions).
Open a calculator sheet, and on the command line, type in solve(ax^2+bx+c=0, x), press ENTER and wait for the solutions
How to solve a quadratic equation
The form of quadratic equation is
The roots of the above quadratic equation are
k24674
ADMIN Andrew
ADMIN Andrew
