Technics SA-DX750 Receiver Logo
Robert Sidwell Posted on Nov 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Receiver power how to hook up an onkyo power amplifer to the receiver
Glen
Level 2:
  • Expert 225 Answers
  • Posted on Nov 12, 2013
Glen
Expert
Level 2:
Answers
225
Questions
0
Helped
82305
Points
395
This is a tricky one. Are you using the Onkyo for only the subwoofer or are you trying to amplify all the speaker outputs?
1helpful
Hooking up our onkyo ht-r340 the subwoofer has 2 line outs left and right back of amp has one subwoofer outlet. what to do
First would be to name the subwoofer so we can look at its "Line OUT's". The IN's would be more important as far as ITS function goes. I'm sure a manual exists for the unidentified subwoofer.
http://g-ecx.images-amazon.com/images/G/01/electronics/detail-page/htr340large.jpg
This receiver has direct subwoofer amplifer for a passive (unpowered) subwoofer as well as a Subwoofer Line Out for controlling an active (powered) subwoofer amp.
What causes protection circuit? How to fix.
Usual cause is a blown power amplifer.
The usual cause of this is shorted speaker leads or excessive load casued by high volumje levels.
I have an Onkyo SKW-50 subwoofer and when I turn on the power to the subwoofer, it is making a low-level humming sound. When I turn the frequency dial up or down, the sound of the hum gets louder or softer...
may be u have a power problem check if ur ground is well connected to ur amplifer and also check the input cables if there ground wires r intact and make good contact
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
I have an Onkyo Av Mod# TX-DS484. The sound is out, all other functions work normally. I did notice that preceeding the failure the sound amplification seemed to be failing (had to turn it up). Is there a...
After receiving information and suggested actions from FixYa it was able to determine that most likely, a power outage and surge had caused the speakers need recalibrating. It was a simple task which utilized the remote, now it works fine.
Onkyo TX-SR805 - surround sound problem
The speaker impedance is not the problem.
Onkyo SR-803 UNPOWERED Subwoofer conectio0n
HI,run speaker cables from "b" speakers out put to speaker in puts on the sub and switch "b" speakers on on the amp.
hope this helps.
CABLE GUY.
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
