Connect the router and computer to create a secure
connection between the two pieces of equipment.
To do this, plug an Ethernet cable into one of the LAN (Local
Area Network) ports located on the back of the Belkin router.
Connect the other end of the cable into the Ethernet port
located on the back of the computer (the side of the computer, if you are using
a laptop).
Access the GUI (graphic user interface) to gain access to
the router settings.
To do so, open a web browser and enter 192.168.2.1 into the
address bar of the browser.
Press "Enter" or "Return" on the
keyboard.
Click on the
"Login" hyperlink located at the top of the page. Enter
"Admin" into the username and leave the password blank.
Click "Submit" to load the GUI.
Click on the "Security" hyperlink located under "Wireless."
Select "64Bit WEP" or "128Bit WEP"
from the drop-down menu and enter in any 10-digit hexadecimal password into the
"Key1" box.
Hexadecimal is a password with both letters and numbers in
it.
Select "Apply Settings" to update the router's
security password.
Use this password to connect your computer and
on other equipment to the router.
The router's password can be changed by running the routers setup cd. If you do not have the cd:
1.Open your browser
2.In the address bar type in 192.168.1.1 this will bring you to your router configuration.
3.put in your username/password "If you forgot your username and password you can always reset your router, if that is the case your router will go to back to default settings,In order to reset the router look in the back of the router and you will see a reset button, press and hold the reset button for 30 seconds, the reset button is located next to the Internet port on the router.
4. When your linksys router configuration is up, go to Administration.
5. change password that's it!! hope this helped. Good Luck
