I can only get it to go off by unplugging it. It comes on but stays at the channel it's at.
SOURCE: Need Emerson Remote for color TV with DVD Player
You need the remote codes for your cable remote? (if so who is your provider?)
or you need to buy a remote control for the tv?
SOURCE: Looking for a remote for an old Emerson TV
Call 1 800 Remotes or go to www.remotes.com. In the middle of the page type in the model number which in your case would be VT1920. I believe the original remote is not available anymore but you can get a substitute remote for that TV. Also have you considered getting a universal remote? Those work on any TV with any component. Try the first two suggestions and hopefully you will find what you are looking for...
Hope this helps,
Sincerely,
Raelyn
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
SOURCE: emerson tv with no remote will not go to aux channel
Need the remote to go to the aux. The number for parts and service is on the back
SOURCE: i have a emerson tv and i'm trying to change the
need remote call parts number on the back of the tv
0002 0502 0006 0115
0506 0706 0520 0906 0316
0505 0614 0324 0924 0626
0826 0027 0327 0128 0228
0632 0134 0247 0605 0705 0805
0703 0903 0004 0519 0106 0104
0304 0604 0804 0005 0105 0305
Be patient and check with these codes one by one, till you find the code for your Emerson model.
NB: Switch OFF and switch ON your TV set, with its front panel power control switch, before trying an other code.
Proceedings
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
OK.
