Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
Wiring a humidifier to a furnace
Replacing an old humidifier on the return duct of a Rheem furnace model rgph-10eamea with a new Honeywell HE240. First of all, what is the full recommended route of wiring needed? The old humidifer was wired into the furnace previously but I have a new plug-in transformer with the HE240; how can it be used to replace the old transformer already connected to the Rheem furnace control board? Thanks in advance. Barry
  • Barry Stevenson
    Barry Stevenson Nov 11, 2013
    Does the transformer need to be in the circuit ? If not, are the connections to HUM and Neutral on the furnace control board? If the transformer is needed, can I simply plug in and connect it to the rest of the components? eg. Humidifier to humidastat to HUM; Neutral to transformer to humidifier.
  • Barry Stevenson
    Barry Stevenson Nov 12, 2013
    According to Honeywell manual, installation can be on either main or return. Placement of exhaust and gas pipes do not permit anything other that replacing existing unit. Do you have an answer for my wiring concerns?
6ya staff
SOURCE:
HANK MCNEIL
  • 252 Answers
SOURCE: I have a carrier furnace, humidifier valve popped fuse
hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Posted on Nov 18, 2009
SOURCE: Can the humidifier's housing for
Hello Which came first the chicken or the egg?The unit will operate perfectly in the supply OR return as I have installed in both.If there is more room & easy service access put it in there.
Posted on Sep 14, 2010
Anonymous
  • 182 Answers
SOURCE: replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
Posted on Jul 04, 2008
Anonymous
  • 290 Answers
SOURCE: he 260a wiring w/humidistat
try this forum...there are wiring diagrams posted there:
http://forum.doityourself.com/humidifiers-dehumidifiers-130/
Posted on Dec 12, 2008
Robert
  • 1033 Answers
SOURCE: I just installed a Honeywell HE 360 Humidifier I
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Posted on Feb 20, 2011
Honeywell he240 no longer working. It is less than 2 months old. I noticed water had stopped flowing out of drain tube. The filter tray is not filling up with water. Humidistat clicks when turned up and...
Maybe the hose is blocked. Take the hose off the supply side, and blow into just enough to add pressure to it and see if that works.
Try this site for more details or a similar issue:
Honeywell HE240 new install not working
Feb 12, 2015 | Honeywell Humidifiers
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
Where do you install it at supply of return duct work???
Actually you usually install on the return at least 6 feet from the furnace...but it can also be installed on the supply if need be...
heatman101
Dec 01, 2010 | Honeywell HE365 Humidifier
What is the purpose of the sailswitch
The sail switch is in the cold air return it is wired in with the humidastat when your furnace goes on the air movement pushs the sail down inside the duct work that makes a contact the lets the 24volts to the humidastat. If the humidastat calls for moisture it turns on the humidifier but only when the blower on the furnace is on So in short it detects air movement
Oct 03, 2010 | Honeywell HE360A1027 Whole House...
Can the humidifier's housing for a Honeywell model HE265 By-Pass Humidifier be installed on the return air duct, or must the housing for this model always be installed on the hot-air supply duct just above...
Sep 14, 2010 | Honeywell Humidifiers
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Replacing thermostat for central heat and air/ not humidifier
May 26, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
777 people viewed this question
Top Honeywell Humidifiers Experts
Dennis Webber
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
