EA - Electronic Arts Need For Speed: Prostreet Logo
A
Anonymous Posted on Nov 10, 2013
Need for Speed Prostreet continue button after a race not functioning. After I complete a race the continue button stops working and I have to end the game. I am trying to play this game on Windows 8.1 and tried several things such as compatibility mode, install / reinstall to different drive, changed settings in game but still nothing works.
  • WALLEDPECIAN
    WALLEDPECIAN Apr 13, 2015
    FINDED THE FIX, DOWNLOAD THE PROGRAM CALLED SANBOXIE AND RUN IN SAN BOX MODE SO IT WILL WORK PERFECT IAM ON REACT TEAM SESSIONS BUT ALSO DONT DO CHEAT UNLOCKALLTHINGS IT WILL NOT CONTINUE IF YOU CHEAT UNLOCKALLTHINGS :) HAVE FUN YEAAHHHH
Young Frankenstein
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 27, 2014
Young Frankenstein
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
17340
Points
Funny story: Follow these instructions and your Continue button will work perfectly. I'm on my third career without one problem on Windows 8.1 Pro 64 bit.
1) Open your Device Manager and highlight the Mice and other pointing devices section.
2) Start NFS Pro Street (it will not start with mouse disabled) and get to the Main Menu.
3) Alt+Tab over to the Device Manager and use your mouse to disable the mice listed under Mice and other pointing devices.
4) As soon as your mouse stops working, immediately Alt+Tab over to Need for Speed and play away. Your continue button will work flawlessly.
5) When you're done playing Alt+Tab back over to the Device Manager and your cursor will still be on the mouse option that disabled it.
6) Hit Enter to bring up the Properties window, hit Tab once to move it to the Enable Device button, then hit the space bar three times. Your mouse is back on.
7) Close the game with your mouse (just out of spite) and remember these few easy steps.
*Unplugging the mouse does not work, sadly.
Evidently there is some problem with the mouse on your desktop stealing focus in Windows 8, I noticed it when I had a mouse cursor in the game on my main screen and saw my desktop mouse cursor moving around on my second monitor at the same time. The two are out of sync somehow and it nerfs the works. This is working for me with Autosave on and off, cracked and non-cracked .EXE, with and without cheat codes, no Gameboost or whatever it is. I did it with both a Logitech gamepad and a Logitech steering wheel and pedals, it's all a matter of having the pad and buttons assigned the right way. After doing this twice, it takes less than fifteen seconds total to do and I get to play one of my fave racing games without worry.
Oh, as a sidenote, those of you having the login problems who bought the game cheap from Origin and downloaded it, I suggest a disc copy. I paid very little for mine and I don't have to log in to a thing. I can cancel the "Connecting to EA" message as soon as it pops without issue. Enjoy boys and girls!
  • 2 more comments
  • Julie Sigtuna
    Julie Sigtuna Feb 07, 2015
    Doesn't work. At all. Just some copy pasted story from a random guy that made this up most likely.
  • Robson Vertuoso
    Robson Vertuoso Mar 26, 2015
    Thanks Dude! Disable the mouse works perfectly for me!
  • Michael Sullivan Oct 22, 2015
    Didn't work . Still finish a race and can't continue
  • Auzy Richey
    Auzy Richey Jan 06, 2019
    Don't work
Auzy Richey
Level 1:
  • Posted on Jan 06, 2019
Auzy Richey
Contributor
Level 1:
Answers
Questions
0
Helped
17340
Points
0
Don't work tried multiple times
2 Related Answers
Anonymous
  • 14 Answers
  • Posted on May 26, 2009
SOURCE: just downloaded more cars forneed for speed
try delete the game data and reinstall it, see whta happens, yo can download your dlc upto 5 times for these very purposes
Anonymous
  • Posted on Feb 02, 2010
SOURCE: Why the NFS prostreet crash while laoding......
This Game dose not suport Windows Vista! i bought the download Version of it from EA-Games Store and contacted suppot they told me it dose not get along with Windows Vista. And i was Refuned my Money
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
I lost my installation code for need for speed prostreet
Well when you get it, the code had writing by it that says "Do not lose this code, put his is a safe place!"
Wel, mistakes happen so, search for a "need for speed prostreet" keygen in google. Some may contain viruses so you'll need to be a little superstitious.
How do i setup the g25 to my ps3
i have a g25 wheel on my ps3 it is simply plug and play.
if you struggle with buttons check this out it has all the functions:
Buttons for the G25 wheel and PS3
Top 4 The Black ones
Top-triangle-cancel-reverse(gear to back car up)
Left-square-cancel
Right-circle-E_brake
Bottom-X-enter You can also use the gas pedal for enter
Bottom 4 buttons The Red ones
Far left-no function
Second button-Change view
Third button-Pause-quick exit replay at the end of race-This button will also speed up the winnings (to keep from waiting with the cup spinning around so you can get back to racing)
Fourth button-best race line for license test
Buttons on wheel
Left-look back (default)
Right-nitro (default)
I change these two buttons around myself so I have the nitro on the left.
D-pad-same as the controller up,down,left,right. For menue use.
Also for (during race)
Look back-bottom pad
Look left-left pad
Look right-right pad
To change any of the button functions use the DFP settings in the options menue.
I have not used the wheel in photo mode. The only thing you can't do with the wheel is "exit" game. I also never have my controller on during gameplay I only turn it on to exit the game. If anyone needs anymore help with this wheel give me a shout-back and I'll try my best to help.
One last thing make sure your wheel is in the far left port(port 1) or port 3
1helpful
Just downloaded more cars forneed for speed prostreet but now the game wont load
2helpful
Prostreet need for speed
get your finger outta your arse
4answers
NFS: ProStreet Freezing
Still same FREAKING problem, get of you azz EA and fix the game of give my money back!!!!!!!!!!!!!!!!!!!!!!!
Top EA - Electronic Arts Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
