The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
SOURCE: internet turns red after 10min of restarting and resetting router
Please make sure that the router is properly configured then only the internet light will be green
Talk to your ISP regarding the router configuration
SOURCE: i have a d-link DSL-2640R
To figure out what problem is, download and install Router Commander Freeware software. Using this program you can view system log messages from router and when problem happens, this log is very helpful.
