My rca f32650 tv set will not show any picture, the green power light flahes on and off. It's making a low clicking nosie in the back. Any suggestions ??
hi there! i hope this will help u find the solutiuons: 1. replace the power transistor at the horizontal section of your tv by desoldering . and buy with the same value, the store assistant in your area will do help you replacing the defective part of your tv. Thank You.
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
The green light indicates that it is getting power from the outlet ok.
The clicking is the power relay trying to turn it on but there is an
internal fault forcing it to shutdown. You either have a power supply
problem, horizontal output transistor (HOT) is shorted or a bad flyback
transformer. In any case it can most likely be repaired by a qualified
technitian. If it is the flyback it may be expensive.
if you are having sound your problem is on the video circuit or related circuit.if no sound on video no power have your tech check the power supply and related circuit.good luck.
