Weiser Lock POWERBOLT ELEC DEADBOLT Logo
Posted on May 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have to change the key code? No manual.
I need to change the combination code on a keyless weiser power door lock, I do not have the manual.
Mark
Level 3:
President:
  • Master 704 Answers
  • Posted on Aug 19, 2009
Mark
Master
Level 3:
President:
Answers
704
Questions
0
Helped
592797
Points
2820
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
  • Marci Ullyot
    Marci Ullyot May 11, 2018
    No longer available. How do I do it
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3761
Points
I dont know how to deleate code lost manual
bustindus53
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Dec 21, 2011
bustindus53
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
12140
Points
26
Simply...
POP inside cover off lock ....
Press the button ( should only be one ) one time to program code one or twice to program code two ...... Punch in your new code and then press the lock button .... Code should now be programed
1helpful
How do I enter new code?
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
I have a weiser combination lock and it seems to be bogging when keying the comb. in so i recharged my batteries and installed back into the lock and it still bogs. Is there one batterie better than...
Weiser has a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Need to change the combination on weiser lock
Follow this link:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Which will take you to the programming instructions for your Powerbolt 1000.
I just purchased a home with one of these types of locks on it & the previous home owner has not left me with the owners manual or the combination of the key pad, how do I program it to change the code
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
3helpful
Need to change combination
3helpful
2answers
Weiser combination lock for front door
You can reset the lockset to change the master code and then enter in other codes for use by contractors, delivery people, etc. which you can then delete as you wish without having to give out the master code.
Rather than give you the simple step-by-step instructions for resetting the lockset, I've provided a link to the user manual so you can have it available for use and reference, as I assumed you didn't have yours any longer.
4helpful
How do I change combo of electronic lock
Have you tried removing the cover (inside the house).. there should be a program button, which you press, enter your code, and press again....don't forget to try your code before actually locking the door...
Hope this helps
Top Weiser Lock Locks & Locksmithing Experts
Sean Wright
Sean Wright
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
