Compressor fails to run , displaying e3 code fan is working ok Unit is in the demand mode. How do I get rid of this code?
SOURCE: E3 is flashing on display panel
Calling two service centers, they both indicated that the main circuit board needed replacing. This would need shipping the unit!!, part and then labor. I figured over $120 - not reasonable. I then took the unit apart and followed the wires from the compressor to the back of the unit. This is where the moisture sensor was located - upper left. You'll see this when you take the filter off. Anyway, I cleaned the face of this part with a old toothbrush, used some compressed air to remove any dust. I then followed the wires with the black sleeve that went to what I think is a temperature sensor - also on the left. The wires go to a sensor that is pushed into a copper tube that is part of the cooling tubing. Gently pull this out, wipe it down and re-install. I then plugged the unit in, set the humidity level and it now works. I just put the unit back together and the compressor is turning on and collecting moisture! I will run it a few days and keep checking on it to make sure it doesn't go into the 'E3' Mode. By the way, the repair shops I called really didn't have a clue what the E3 code was. Dennis
SOURCE: The unit just stopped extracting any moisture from
If the unit isnt extracting moisture in the air you have one of two problems a leak in the refrigeration system or the compressor is locked up. In my experience its probably a leak in the refrigeration system because they make the dehumidifiers very cheap and the coils are paper thin. Delonghi has a lot of issues with there dehumidifiers and any other appliance they make. Check to see if the compressor is running if it is then you have no freon in the system. You can access the compressor by the back panel and you will know if it is running. If it is a refrigeration leak buy a new unit it will be a whole lot cheaper and less stressful,.
If this helps please rate me.
