F3R0184043235
SOURCE: I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
SOURCE: free download of d-link wbr-1310
just click below link and select your country code you can download
the installation guide for free
http://support.dlink.com/products/revision.asp
SOURCE: dlink wbr-1310 quick installation guide
http://www.dlink-india.com/products/Product_temp.aspx?id=9,437
download it
SOURCE: how do i reset my password as i have forgot the password
The easiest way is to reset the router. Look for a very small recessed button on the back panel. It should be marked reset. You will need a paper clip or a similarly sized probe to push this button. The router needs to remain on for this entire process.
Push and hold for at least 3 seconds. When you release, the unit will have all the factory settings. You will need to reprogram everything from scratch. Your ISP tech support will be able to guide you. Make sure that you secure it so your freeloading neighbors will not be able to use your signal.
