Question about RCA 24V511T 24" TV
RCA 24v511T remove cover replace fuse
Standby light not coming on. However, when I manually press the power button I can hear the TV attempting to power up. There was a power surge in the area amd I had these symptoms once before. It's been awhile and I was just trying to remember what needs to be done to remove the rear cover and replace the fuse.
6ya staff
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: RCA Model F36450 Chassis ATC113CA1 won't power up
No sir it probably isent a power supply problem as in these sets it wouldnt act like that. First thingm to check since you say your a service tech, is in the horizontal output check and see if the horiz. output transistors shorted. If its not then check a small coil off the base of the horizontal output transistor. its really the base drive coil so take it out and scrap off the ends BOTH ENDS and reinsert and also resolder the horizontal driver transformer. This may or may not fix your problem But if it dosent order if you think ther sets wrth it the flyback transformer as this is a big problem in these sets if the for mentioned things did do the trick. follow the kit instructions that come with the flyback transformer!! Dont take any short cuts. Make sure you do take out the horizontal output transitor or at least unsolder all the leads when tesating it for a short. Good luck
Posted on May 21, 2006
Anonymous
  • 3130 Answers
SOURCE: tv will not power up
no reset button ,sorry. The problem you describe is pretty common with this model as its a fault in the horizontal drive circuit or in the main power supply and without the proper service manual as well as the prober tools and equipment this set its not gonna get fixed. there are no panels or user changable boards as it is a solid state set. ptscorp.com could repair this board or exchange it with a referbished board but it would still requir some adjustment that a user may not be able to handle. time to call the pro.. Sorry couldnet help ya more.. Good Luck.
Posted on May 24, 2006
Anonymous
SOURCE: Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Posted on Jun 23, 2008
Anonymous
SOURCE: RCA 27' tru flat sdtv- power light comes on- no display,no sound.
How do you unlock your TV from Protective Mode? There is a certain code that you need in order to unlock the Television. The technicians are saying that it went into Protective Mode, when it umplugged all by itself. I need the code so I can watch my TV again.
Posted on Nov 24, 2008
Anonymous
SOURCE: I need to remove child lock (without remote)
hi did you get to solve your problem becuase i have the same problem
Posted on Jun 11, 2009
RCA TV Model 24v511t standby light stays on and TV will not turn on
Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Oct 07, 2015 | RCA Televison & Video
I have a Sony FD Trinitron Wega (KV-32HS510). When I attempt to turn the tv on by pressing the power button on the remote or on the tv, the standby light comes on and I hear two clicks but tv don't...
The primary power supply is good,maybe the horizontal output transistor is deffective thats why there is no high voltage supply in the picture tube because theflyback have no supply voltage and oscilation.So check the harizontal output transistor and replace if deffective.
Sep 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Lost remote tv wont come on stand by button is red what do i do
if the tv is like mine without a power button on the tv try a universal remote or order a new one from rca.
Jan 29, 2011 | RCA 24V511T 24" TV
I have a RCA model 24V511T can I hook up a roku receiver to view Netfliks etc from the internet. I have hooked up the red white yellow connectors to the input ports on the tv set and nothing happens?
First of all, make sure all components are powered up and plugged in. Next, check that your tv is set to the correct input by pressing tv/video or input button on either the front of your tv or at your remote. Scroll through the inputs by continuously pressing the input button until the see the roku video displayed on your tv.
Good Luck
Jan 07, 2011 | RCA 24V511T 24" TV
I press the power button and hear the click but no picture appear
Unplug the TV Remove the cover wait until the TV cools then plug in, turn on and, it should come on... if it does; purchase a computer fan to cool the chassis of the TV wire it into the 12 volt side of the power supply and, install the cover
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
FPA lock on; have no remote control
FPA Lock On and have no remote for the TV on a RCA TV
May 20, 2009 | RCA 24V511T 24" TV
RCA 24V511T Vertical problem
There is a problem with the vertical circuit. In many cases this is either poor solder connections or a defecitve vertical IC. If you can solder you should be able to fix this yourself. Please note that there are potentially dangerous high voltages present inside the set even when unplugged. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Thanks,
Dan
Jan 30, 2009 | RCA 24V511T 24" TV
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV Repair Assistance needed
FLP stands for -- Front Lock Panel - I found it in a friends RCA TV manual. It is a lock you can place on the tv front panel buttons. When this is locked you can only use the remote. So once I knew that I went to RCA Service Center and ordered a new remote.. problem solved. So since your person couldn't even understand my problem, let alone solve it. I would like a refund please.
Thank you
May 30, 2008 | RCA 24V511T 24" TV
RCA 24V511T 24" TV Logo
35 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
