The screen has gone dark.
SOURCE: i want to know how
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
SOURCE: Installing a spring in the Timex Ironman WR 100M watch
That spring is called COIL SPRING and it transmits the signal from the microprocessor to audio membrane fixed to caseback. This is how you hear all the beeps, alarms, e.t.c.
Examine watch movement and you should fine small hole (it can be even marked with an arrow and writing: COIL SPRING).
Fit that coil spring in to the hole and close the caseback. If you hear no sound, you fitted it in the wrong hole, so, refit the coil spring till you find the right hole and hear the beeps.
Rate, please.
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
SOURCE: How to set time on Timex Ironman watch
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
SOURCE: can't find replacement strap for timex icontrol 50
replacement strap for timex ironman i-control 52220
