Im having the same problem with my zeepad android 4.0 tablet. the camera itself works. but it doesnt work with applications. (skype, oovoo)Im having the same problem with my zeepad android 4.0 tablet. the camera itself works. but it doesnt work with applications. (skype, oovoo)
You can't post conmments that contain an email address.
Please try this:
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message. Note: Cust may see the "Demo mode" icon in the homescreen, however it wont bringup Demo Video
It is different depending on which zeepad you have. From powered off, which yours sounds like it is:
1. Hold down both volumes and power at the same time. You should get an android on its back opened up.
2. Press both volumes at same time to open up a small blue text menu.
3. Then use Vol - and Vol + to navigate the Recovery mode.
4. Select "Factory Data Reset"
5. press power
6. choose "yes" from the menu
7. then press power again.
If this does not work try holding down the volume and power at the same time.
could be corrupted data or bad app,going to settings and reset to factory default that should fix corrupted data, if it still persists check for firmware updates in the settings, then check for app updates. if it still exists after that return back to factory for warranty repair
