My picture looks good but every few minutes it will blink a few times, and then be fine for a few minutes and then blink a few times and then be fine again.
SOURCE: my 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
SOURCE: Mitsubishi DLP - WD-60737 -
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
SOURCE: MITSUBISHI 73 INCH 1080P DLP
turn down volume see if you hear a noise from back where color wheel is located
SOURCE: My girlfriend's Mitsubishi WD-62528 TV has a
Hi:
The problem you are describing is due to a faulty LCD screen inside the light engine. The only option for solving this problem is to replace the light engine.
You may get a used or refurbished one if you check the internet or try this site.
www.tristartmodule.com
