I have two rows of white dots across the top of the screen when tv is on. What could be the problem?
SOURCE: SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
SOURCE: Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
SOURCE: Blue Dots on the screen of my Sony LCD Projection TV Model KDF-50
Did you check the lens to see if dust or residue may be on the projector. You may need to call a repair technician to open up the screen and look inside
Hope to Help
SOURCE: sony kdf-55e2000 tv
This indicates problems with the image engine. (Lamp does not control the colour). If the TV has not been cleaned recently, excessive dust build up internally may have overheated the image engine. If Sony will not cover it, you might want to consider a new TV.
Testimonial: "thanks, tv is only two years old and don't want to buy another one. Hope it is not the image engine."
