How do you remove the main conrtol board?
Your best solution is to call Electrolux Home Care and find your nearest warranty station, even if you are no longer covered.
They will know how to perform this fix conveniently...unless you already have the new SUMO board. If that's the case contact me here, if that's possible, and I'll try to lead you thru the steps.
It is possible in this case that the program controller unit is faulty as it is working erratically. Now if there is a possibility that insects have gone into the board sections itt can secrete and damage the board to short at times. So open and remove board , clean using petrol on the board and reset. check all teh connectors , teh door switch and the front panel-- this is also a suspect if there is no response.Please check the cost of a new board to thenew oven and deccide.
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
