there must be fault in hardware of your mobile.. kindly restart the phone and use it.if still have the same problem you should format the phone . if still some problem. kindly change the display screen of your mobile. there should be fault in display screen of the mobile. kindly change the screen this will able you to fix this problem
The problem is from the ribbon that attach the screen to the main board of the phone, it is not properly connected that is why you do not have display. If the phone should have fallen, then the screen might be faulty. If it did not fall from you, then it means the ribbon of the screen is disconnected from the phone.
First, try to flash the phone, then you open it up carefully. And sit the ribbon that links the screen to the main panel of the phone properly.
And if that does not help, then you need to replace the screen of the phone.
Hi,there are there kinds of white screen in phone, the first one is because of damage LCD (glass screen) , defective display driver (small chips that makes the display works) and the other one is corrupted software...in damage LCD the phone will detected,and thirdly, The flex of the phone. The flex is connected to the screen and it makes the screen display,if the flex gets damaged it will make the screen display be affected.
Pl go to the service provider's site and look for your mobile phone's WAP settings there. All service providers has most of the popular handset's settings in their website.
another display in low cost ,just change the display dear
