USB controller
Although many computers
have an integrated USB controller on the motherboard, many computers may
also have an expansion USB controller card. If your USB connectors are
not connected directly to the motherboard it is likely your computer is
using an expansion card.
Motherboard USB controller
If
your USB controller is integrated on the motherboard it is generally
best to consult the motherboard documentation or visit the motherboard manufacturer's web page for online documentation regarding your USB controller.
Expansion card USB controller
If your USB controller is an expansion card it would be best to refer to the manufacturer's documentation or visit the manufacturer's web page for additional information about your USB controller.
Note:
If your USB controller is currently installed and working and you are
running Microsoft Windows 98, Windows ME, Windows 2000, or Windows XP,
you can determine the USB controller currently installed by opening the
Universal Serial Bus controllers category in Device Manager. For example, "SiS 7001 PCI to USB Open Host Controller" indicates a computer is using the SiS chipset.
For more detail specifically to your product, check it!
http://h18000.www1.hp.com/products/quickspecs/11876_div/11876_div.html
best of luck!
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you dont have a motherboard disk you will need to download the drivers http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
hope this helps you
Types of High Speed USB (USB 2.0) Host Controllers
· Intel Enhanced
· SiS Enhanced
· VIA Enhanced
· ALi Enhanced
· Standard Enhanced
· NEC Enhanced
The system shown has onboard Intel High Speed USB (USB 2.0) with an NEC High Speed USB (USB 2.0) PCI card installed.
The key word is ENHANCED. If you have an ENHANCED USB Host Controller then you have High Speed USB (USB 2.0)
All other types are USB v.1.1
hope this helps
