SOURCE: Need a replacement kneading blade
try http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
SOURCE: lost 18V AC adaptor- can I use one made for laptop with 18V output?
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
SOURCE: I need directions to replace string on black and
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
