No termina de hacer el post
SOURCE: konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
SOURCE: I have a konica minolta magicolor 4650, that
ACK!
No.
You will need a Technician to format the machine to restore to defaults.
SOURCE: No tengo treiber para konica
Thank you for contacting Fixya.com
Please download the drivers from the bellow mentioned link:
http://www.howtodrivers.com/model532191.html
Good Luck and God Bless.
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
SOURCE: My Konica Minolta Magicolor does not fully
Update the firmware using the following link:
http://kmbs.konicaminolta.us/productsattachments/manuals/FirmwareUpdaterGuide.pdf
The following manual was read by me. The Troubleshooting section and error message section didn't mention the 256 MB memory ram error.
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor4650EN_4650DNUserManual.pdf
However, there is supposed to be an 'initalizing' message if the printer is initializing.
Also, there is a 'memory full' error when there are too many fonts on the memory card, but this is not something you mentioned.
If you can't solve the problem with the above, I would consider having the unit serviced by Konica Minolta.
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html?model=magicolor4650&cat=Printers&subcat=magicolor&SsdModelId=1042%26productid%3d1041
877-778-2687 is the number for service information at Konica Minolta for your printer.
Please call 877-778-2687 for service information.
