This should be a simple solution rock your vehicle forward then reverse on running engine
they call this trans lock usually happens on hills or pressing down the shifting knob
get a few friends to help push forward if cant start vehicle because in gear its like the old 4x4 hubs in order to get out of lock it needs to be rolled a little
my little 4x4 did same thing called a friend he told me same way to fix
SOURCE: 99 buick Lesabre
hey thanks for bringing me up to speed. ive been working on many other problems but with your great explanation i remember.
we need to check the compression on that cyl. and compare it to the compression on 2 other cylinders your choice.
but before you do this get a can of carb cleaner . and with the car idling spray around the intake manifold in the area of #6 cyl. what we are looking for is a small vacuum leak that would also act like this. with the engine idling and spraying around the intake the engines idle sould not change and if it does when you spray you have an intake leaking.
let me know how it turns out.
later
paul
SOURCE: Suzuki sidekick fuel gauge working backwards
Sounds like you have a bad fuel gauge sending unit.
SOURCE: suzuki sidekick clutch problem
Check the cable clearance. Too much clearance will cause clutch slippage or total clutch disengagement. Adjust the cable so that the clutch pedal will be hard to press by hand .5 to .75 inch from its initial point.
SOURCE: 2004 Chey Optra LT engine light is on and there is
i want to buy a new engine for my car 2004 chevrolet optra LT can you hepl me
