Question about Hardware & Accessories
Brinks 46 1022
I have a brinks in wall timer 46-1022. It now will not turn the lights off at all. I have tried the reset button, the manual button, and resetting the program. But the lights won't go off. any ideas??
    Top Expert:
  • Hardware & A... Master
  • 55,370 Answers
The timer could be defective
Posted on Nov 09, 2013
6ya staff
SOURCE:
Anonymous
SOURCE: Brinks model 44-1050 digital outlet timer- I don't
I have an instruction for a Brinks 44-1030 which I believe programs the same. If you email me at tedban@gmail.com I will send you a PDF scan of the instruction.
Posted on Jan 08, 2010
Anonymous
SOURCE: brinks 44-1030 manual i need a
1) Can you describe the timer in detail?
The buttons and the dial, shape, if it plugs in or is programmable, whatever you can think of to illustrate what timer looks like.
I have extensive files on timers
Most brinks timers are versions of other timers, and manuals exist for those timers.
Add a comment with the information, and I will post a manual if timer matches other brands.
2) You can open following link and see if your timer appears on the page:
Manuals appear for each timer on page with a few exceptions.
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) Another step would be to buy the 44-1030 at Walmart and scan the manual into .jpg format.
Download Cute-writer the free pdf software.
Print your .jpg image but select cute-writer as the printer.
Instead of printing, the software makes a pdf manual.
I use this technique when I need a manual
Title your new manual and post it on the internet for sale.
Return the timer for a refund.
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you describe timer.
Posted on Jan 10, 2011
Anonymous
SOURCE: instructions for programming a Brinks model #
Manual is shown on links below:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1030-manual.pdf
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 19, 2011
duary2
SOURCE: Need programming instructions for Brinks 44-1040
Go to waterheatertimer.org/pdf/Brinks-44-1010-manual.pdf Make sure you Cap the 'b' in Brinks
Posted on Mar 02, 2011
duary2
SOURCE: I need a users manual for a Brinks timer model
Go to waterheatertimer.org/pdf/Brinks-44-1010-manual.pdf Make sure "b" in Brinks is a cap.
How do you reset timer for brinks 44-1011
stick end of paper clip or toothpick into reset home to reset timer to faCTORY defaults
This will clear memory settings that occur during manufacture and testing
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/brinks-timers-and-manuals.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 13, 2014 | Hardware & Accessories
How to set timer the Brinks 44-1011 timer.
Often the reset button is small round hole
http://waterheatertimer.org/Brinks-timers-and-manuals.html
Gene
Aug 29, 2014 | Hardware & Accessories
Brinks 46 1022 has stop working after 8 months. Rest it but it's still not working. How do I get it working again?
Brinks timer has one year warranty through hamptonproducts.com
Hampton does answer emails in 2013
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Try resetting timer
Add a comment and describe timer in detail so it can be identified.
Buy another Brinks from Walmart and return defect in new package.
Buy Intermatic, Woods, GE timers instead of cheaper-made Brinks, First Alert, Westek, Westinghouse, Timex etc
May 26, 2013 | Hardware & Accessories
I lost my isntructions for Brinks 7 day in wall digital timer controlling my overhead light Help.
Copy following link for Brinks manuals:
Possibly the 44-1022
Add comment and describe timer, or attach photo
Apr 05, 2013 | Hardware & Accessories
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Brinks timer 44-1030 .
Reset the timer, and reprogram.
Do not exceed the 500 watt incandescent maximum
Test outlet for correct polarity and grounding using circuit analyzer.
Try timer on different outlet and different load.
Buy another $$12 timer from Walmart and return defective timer in new package.
Sep 06, 2012 | Hardware & Accessories
The on/off button quit working. I can't manually turn lights on/off. In wall timer ST01AC
Thank you for including timer model number.
You have almond-colored ST01AC timer that worked before and then stopped working.
The manual override no longer turns lights on-and-off.
Manual override works by pushing in timer door, and also by pushing on-off button on face of timer.
1) Try pushing on-off button directly instead of timer door, in case little plastic point on timer door has worn down. If timer door is worn down, maybe add a few layers of tape so door can push button again.
2) If timer on-off button is not working, then timer may be defective -or- timer CR2 battery needs to be replaced, and then timer reset and reprogrammed.
3) Defective timer: timer has 1 year limited warranty against workmanship defect
http://www.intermatic.com/customer%20service.aspx
4) Replace CR2 battery, reset timer, and reprogram timer and see if functionality is restored.
If timer is not restored, then timer is going bad.
Open following link for illustration of battery replacement, steps for resetting timer, and illustrated re-programming steps.
http://waterheatertimer.org/ST01C-program.html#battery
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
Hardware & Accessories Logo
129 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
