Can you unlock my nokia 5130c-2 I have problem with my security code, I give my security code correctly but I can not unlock my nokia 5130c-2
SOURCE: All this code like*#7780#, *#7370#,*3 call etc is
Those "codes" are dependent on a few factors as to whether or not they'll work.
*#, or ## codes are typically found amongst the CDMA providers, and not so much the GPRS. CDMA = Sprint, Nextel, Boost, Cricket GPRS = Verizon, ATT, TMobile, etc.
Depending on what you mean for a "hard format" I might be able to help you, but I don't have the correct information, and your description is too vague to help you any further than this until I have more information.
I need your phone's model
Service Provider
and you'll have to have your MSID or EIDE (those are codes that are on your phone behind the battery) and you will need to use those to gain access to a menu that's built into the operating system on your phone to do what you're trying to do more than likely.
You can gain more information by calling technical support, and claiming to have an "issue" with connectivity, and they may be able to get you into the progamming menu on the phone, then you may find the option yourself.
Good Luck
Dracconus
SOURCE: i change security codes for
my xpressmusic code is lock pls help me to unlock the code the maste code do work
SOURCE: i forgot my security code of my nokia
Hi!
Please tell me your phone IMEI number. It is the 11 digit code so that I can assist you with the unlocking.
Or you can do it yourself here:
Reset Nokia Security Code
Use the calculated Master code as the moment your phone is asking for the security code
I hope it helps.
Please leave comments for further assistance.
Thank you for reaching us.
SOURCE: Forget my mobile security code(Nokia 5130c XM)...Plz Help
4745066750 try this. it is your master code, hope it helps
SOURCE: nokia 5130c-2 forgot security code
hi
visit on this site http://www.unlockme.co.uk/master.php
after visiting on that site you have to enter your phone's imei no. in the textbox which are given on that page
after entering your imei no. click on get master code button to get your phone's master code
