A) To resolve the initial BIOS lockout, download the most recent BIOS firmware, and flash the system if possible.
[ Note*
1) IF, there is a power outage at your home/business, when flashing the BIOS, your motherboard becomes an expensive paperweight.
It isn't it may happen, it IS do Not lose power, or this will happen. However this goes with number 2 below also,
2) When flashing the BIOS program it will be asked (Should) if you wish to create a backup, before proceeding to the flash.
The answer is Y-E-S.
Should something happen as briefly described above, you will have the original BIOS program backup to go back to ]
B) Then remove your harddrive, install it into an economical 2.5 SATA external enclosure, and pull your personal info off by attaching the external enclosure's USB cable, to a working computer.
Then reinstall the harddrive, and use the Recovery Disk to Repair.
(Non-Destructive Installation)
You May be forced however, to perform a Full Installation instead.
(Destructive Installation)
You will have your personal information because you saved it. You will however, have to reinstall programs/applications.
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Harddrives come in two different sizes, and technologies, at present.
A harddrive is measured across it's Width.
A laptop harddrive is 2-1/2 inches across.
A desktop harddrive is 3-1/2 inches across.
The two technologies being used at present for harddrives, is IDE (PATA), and SATA.
The Satellite L455D series uses a 2.5 inch SATA harddrive,
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,P000506260.aspx{ Not stating the original harddrive was an Hitachi. Showing that the harddrive uses the SATA technology. It is already known that the size is 2.5
It is a laptop harddrive }
This is information on IDE (PATA) technology,
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1This is information on SATA technology,
http://en.wikipedia.org/wiki/Serial_ATAThis is but one example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783Use Anti-Static Precautions when working on your laptop.
Be Sure ALL power is removed. AC adapter (Charger) and Battery.
