SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
SOURCE: fossil watch me1001 bracelet adjustment
I took mine to a watch store, and had them remove a link.
SOURCE: need to change the battery
good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
SOURCE: Need manual and battery info for Fossil S+ARCK PH-1002 watch
Of course, you can.
Open the watch and take the battery out. Memorize all the writings on battery and buy exactly the same one. You need to memorize wich way up the battery is originally fitted. If you will insert the new battery the other side up, you can damage your watch movement.
Rate me, please.
