I have a Kitchen Aid Superba Side by side ref Model # KSC25INSS00 It seems to be experiencing the same problems that the Maytag refrigerators are being recalled for. Kitchen Aid said it was probably the relay switch that has failed. 1. If this is it, why is Kitchen Aid not recalling their products too? 2. Does anyone know if they are experiencing the same problem? Compressor will not shut off, and the center bar between the ref and freezer is extremely hot to touch. 3. Can I replace it myself? I just fixed my DLP Color wheel this week... Thanks! Molly
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
It is working correctly now. I am not for sure what did it, but I turned the refrig off, empty all the contents, and cleaned it. Then I took off the panel below the ice shoot (on door, inside) and there was ice build up in there which should not have been. I did forget to remove the ice when I defrosted last, so the water must have leaked into this compartment. Temp is right, bar is only slightly warm now. Yeah!!! Thanks!
