One switch will be used for a light and the other switch is used for the top half wall plug. I have two 14-2 w/ground coming in the top of the two switch box and one 14-3 w/ground coming into the bottom of the two switch box. The 14-3 with ground on the bottom of the box goes to the wall receptical and is used to power only the top plug. The two 14-2 with ground wires the come into the top of the box are .. one that is the power source and one that goes to a outdoor light. How do I connect all the wires together to make these switches work correctly??? If you have a diagram the would be ideal to help me.
SOURCE: I bought Utilitech #0141224 7
If your box contains 2 and only 2 wires, then the Utilitec timer will not work.
You need the Intermatic ST01C or EJ500 timers that operate with a battery.
I have tested the Intermatic and Utilitec timers:
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
http://waterheatertimer.org/ST01C-program.html#wire
Do not connect white and red wires together on any timer, but thank you for solving the problem why lights blink when connecting timers.
Now lets look at your wires.
Scrape paint off the wires so you can identify white and black.
According to your information, the black wire inside box will connect to timer-black wire.
The red wire always goes to Load (your light, fan, motor)
The white wire is necessary to complete a circuit so the clock inside timer will operate.
The timer has a clock just like your alarm clock, and it needs to connect back to neutral busbar in breaker box.
This is why the battery-operated timers will work with two wires, the clock runs on battery.
The Utilitec timer-white wire is the wire that goes to Neutral
The timer-white wire is supposed to connect to the other white wires that are twisted together and covered with a wire nut ... but some boxes do not have this neutral wire
To work-around, the timer-white wire can also connect to a bare ground wire.
The bare ground wire also connects to Neutral busbar in breaker box
If you do not have a neutral or ground wire as described above, then you need the battery-powered ST01C or EJ500 Intermatic timers.
See if you can pull some more of the wire into your box ... there might be a ground wire that was cut off and pulling more wire might reveal a ground wire. This will salvage the project.
Aplus is one of many places that sell the Intermatic timer
http://www.aplussupply.com/intermatic/timer.htm
For more about electric wiring:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
