Hello! I think that the information which is posted here will be really helpful for many of those who are working in the area of writing web articles. So you can visit them right here: online paraphrasing service
Fax board error did you replace it or remove it?? was it installed ? did you install correctly there is a procedure
SOURCE: bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you
need to use the option that scans to SMB, that sends the scanned
documents to your computer on the network. You can then process
the documents on your computer with the OCR software program so you can
edit the finished documents. I did not see anything that
indicated the Bizhub had OCR software capabilities built into the
unit. Regards, rcampsr
SOURCE: C-2451 on bizhub c450
C2451: New Transfer Cleaner Unit resetting failure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch
ON while pressing the Utility/Counter key.
3. Touch [Trouble
Reset].
4. Check to make sure that [OK] is displayed and the
it has been reset.
5. After turning off the Main Power
Switch, turn it on again more than 10 seconds after and check if the machine
starts correctly.
Reset your Toners and
Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
SOURCE: I have a C-2557 code on a bizhub C450
interesting... this information is covered in detail in this post http://www.fixya.com/support/t1232734-bizhub_250_malfunction_code_c2557_help
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
