With batteries and charger at room temperature, in any port, the red flashing sensor indicator never cycles to charging mode (ie the green light never begins flashing)
SOURCE: Ryobi Model 1412001, 16vdc, 2A
I've open the charger and found that Q4 is open. But they have removed the part number from the component so you can't get a replacement.
SOURCE: Some Ryobi 18v batteries charge, others don't.
Had the same problem with some makita batteries, Was going to throw them away so decided to take apart and see what was happening. The are made up of 1.5 volt cells soldered together, found that many had .9 volts or less and others had 1.5 or more. This means that some of the cells had gone bad (probably due to lack of chemical reaction). Found that if I collected all of the 1.5 volt together could charge just fine. Problem is it is very hard to get them all soldered back together and even harder to enclose them. If a mfg. could come up with some way to change cells individually they could make a lot of money and save us a lot. So the answer to your question is buy you at least one more battery and recycle your old one.
SOURCE: The Yellow and Green light both come on and stay
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more
than 15 minutes it probably a defective battery pack. See page 8 in the
manual.
SOURCE: Ryobi p111 charger -- light stays red
My charger do the same thing. I talked with the service people at Ryobi who said that the red led never goes out no matter how long you charge it. They suggested just charge it for 12 hours and then disconnect. Pretty dumb system, but that's apparently the way it is.
SOURCE: One of my Ryobi 18v battery packs (1400672) won't charge.
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
