How to access any "Engineers Setup Menu" for a TV THOMSON 37MH44E to adjust PinCushion Distortion (The vertical edges of the picture curves inwards the picture and the corners of the picture are pulled out of the tube) OR what is bad and what must I do to recalibrate the picture ?
SOURCE: Loewe TV with pin cushion distortion
Yes if you could give me a model #, it is probably a diode shorted in pincushion area, or a capacitor.
SOURCE: Picture distortion
This should cost you about 300 to 400 bucks to repair. If the service wants more, they are ripping you off. The convergence IC's are whats bad in this set and both of them cost less the 30 bucks. Good Luck
SOURCE: curved picture
ur problems is on the pincushion check for a capacitor that its bad on the pincusion section good luck.
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
SOURCE: How do you get into the service menu for a LG WE-32Q10IP TV?
Press and hold menu button on your TV and menu button on your remote at the same time.
