Water line ok
SOURCE: Ice maker won't fill
I had this problem with a Kitchenaid and Sears rep advised me to pour some water in the tray. Did and the ice maker started working in about 90 minutes.
SOURCE: Ice Maker won't work...water line frozen?
HOLLOW ICE FOLLOWED BY FROZEN WATER CHUTE ARE THE FIRST SIGNS THAT THE WATER INLET VAVLE IS OR HAS FAILED, IT CAN ALSO CAUSE DAMAGE TO THE ICEMAKER BY BURNING OUT THEN TIMING GEAR DUE TO INSUFFIENT WATER OR FLOODING IN ICEMAKER WITH TOO MUCH WATER
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
SOURCE: Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
SOURCE: Ice maker not getting water. Everything else seems
You will have to remove the icemaker and look inside the water fill tube at the rear wall of the freezer.
The water line may be frozen closed.
If so,take a hair dryer and thaw it out.
This manual will explain other test to complete.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
