SOURCE: Only three months old and
My research shows that a consumer gets a 5 year warranty and a commercial user gets a 2 year warranty on any Echo equipment they buy. Could you consider getting some warranty service on this unit since it is still under coverage? It sounds like a fuel delivery problem (carburetor adjustment maybe), but I also realize that some of the newer "rotary" type carburetors in use don't have the Low and High speed mixture adjusting screws like the old-style diaphragm carburetors that preceded them.
SOURCE: I have a new echo
sounds like a dirty carb, dissamble it and rinse good with carb clean, be careful when taking the top off it that you get it back together the same spray the white center good and all little holes good. then reassemble, also try to loosen your gas cap maybe first before cleaning carb, you might have a plugged vent in the line coming out of the tank. Good Luck
SOURCE: Blower starts and runs for
I don't think the oil-gas ratio will cause that problem. Did you check to see if the fuel lines or fuel filter is clogged?
