Belkin Components F5L009 5 Port Network Usb 2.0 Hub 5 X 4-Pin Usb 2.0 Logo
Posted on Nov 07, 2013
Need windows 8.1 driver for SXUPTTP
USB Hub will not work with windows 8.1 says it needs updated SXUPTP driver
VWMech
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Nov 08, 2013
VWMech
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
11107
Points
46
It is compatible: http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Belkin%20F5L009%20USB%20Hub&vendor=Belkin&Locale=1033%2C2057%2C3081%2C4105%2C16393&BreadCrumbPath=Belkin%20F5L009&LastSearchTerm=Belkin%2BF5L009&Type=Hardware&tempOsid=Windows%208.1
Try opening device manager (Windows Key + X then select device manager from the dropdown) Find your device: Look under "unknown devices" or "universal serial bus controllers", right click and select update driver software.
Need to reset a digiland dl808w tablet NO TOUCHSCREEN
I know how fix it if any still need help. You will need usb with windows 8 install on it, keyboard and micro usb hub, which take other devices get things from it, like gettin gwindows 8 start on tablet digiland. You need start device, press winodws key and alt, then it should start over bios mode, then go to first slot start windows 8 usb, then restart, wait it fully go usb then should be windows 8 install done right after waiting say 5-8 minutes see it, then should be able take it from there. I did it but having problems with updates it needs, which working on. Hey least get winodws 8 right.
tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
The computer can not recognize drive (unknown USB device).
Method 1 - Unplug Computer So how did I finally fix the problem? Well, if you are lucky, it's a super simple solution! Try this method first and if it works, you'll have saved a lot of time.
Simply unplug your computer from the power supply. Yes that is it! Note that this does not mean just turning off your computer using the power button because most modern computers don't actually turn off completely and the motherboard will still get power. This is useful sometimes if you want to remotely wake up a computer, etc.
The motherboard is where all of hardware of the computer connects to, including the USB ports. Sometimes the motherboard needs to be "rebooted" because things can go wrong, i.e. all or some USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should hopefully be recognizing devices again.
So first turn off your computer using the Shut Down option in Windows or pressing the power button and then UNPLUG the PC from the wall outlet. Let it sit for several minutes and then plug it back in.
Method 2 - Update Device Driver If Windows is not able to recognize the device, you may also see in Device Manager that the device shows up as an "Unknown Device". You can get to Device Manager by clicking on Start and typing in devmgmt.msc or by going to Control Panel and clicking on Device Manager.
In that case, you should right-click on Unknown Device, click on Properties, then the Driver tab and then click Update Driver.
If this doesn't work, you can also try to download the driver for your device from the manufacturer's website. If the USB device is just a flash drive, then it's probably not a driver issue. However, if you are installing a USB printer, drawing pad, etc, then it might be worth downloading the driver for that specific device.
Method 3 - Restart & Disconnect USB Devices The next thing you can try is to disconnect all USB devices and then restart the machine. once you have restarted, try to connect the USB device that was causing the problem.
If that particular USB port doesn't recognize it, try another one. If the device is recognized by a different USB port, there could be a hardware problem with one of the USB ports. If no USB port recognizes the device, then keep reading because it's probably something else.
Method 4 - USB Root Hub Another thing you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties.
Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box. If you have more than one USB Root Hub listed, you need to repeat these steps for each one.
Click OK and then restart your computer. Try to reconnect the USB device and see if it is recognized. If not, go back to the power management tab for each one and check the box again. If it does recognize the device, then leave them unchecked.
Method 5 - Connect Directly to PC A friend of mine ran into this issue and the cause ended up being his USB hub. He only had three USB ports on his computer, so he bought a hub where he could connect an additional 8 USB devices.
I guess this proved too much for his computer and it just started sporadically not recognizing various devices. After removing the hub and connecting the device directly to the computer, it worked just fine.
We haven't really been able to find any other solution to this problem other than reducing the number of items connected to the hub. Actually, one other solution worked, but it meant having to buy a new USB hub with more power.
If you are having this problem with Windows 8 or Windows 8.1, then you might be in luck. Microsoft has released a fix for Windows 8 not detecting USB devices properly. Make sure to install this hotfix if running Windows 8.
Method 6 - USB Troubleshooter If nothing has worked so far, you can download the Windows USB Troubleshooter Fixit tool. It's a free tool that works with Windows XP, Vista and 7.
You can either have the troubleshooter fix the problems for you or select the fixes yourself. I would just let it fix them for you since the choices can sometimes be confusing and technical for the novice user.
Method 7 - Update Generic USB Hub If you are getting the Unknown Device error in Device Manager, you can also try one other thing. Open Device Manager and then expand Universal Serial Bus Controllers.
You should see at least one item called Generic USB Hub. On some computers, you might see two, three or more of these. Right-click on the first one and choose Update Driver Software.
When the update dialog pops up, choose Browse my computer for driver software.
System error found
Hope this will help someone else:
InWindows' Device Manager (devmgmt.msc), the SXUPTP driver was showing as disabled.Windows gave a warning that the device was known to have stability issues. Ifound out that SXUPTP is a driver from a company called Silex. Silex makesnetwork USB hubs, so I assume that the Belkin hub is a rebranded Silex hub.
In order to update the Silex driver follow these steps:
1. Close the Belkin network hub's tray application.
2. Download the latest version of SX Virtual Link(sx-virtual_link_win_3120.zip).
3. Extract all of the files.
4. In Windows Explorer, navigate to sx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVistaX64if you are running a 64 bit OS, orsx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVista if you arerunning a 32 bit OS.
5. Right-click on "Sxuptp.inf" and select "Install" fromthe menu.
The driver will be installed and the warning icon in the device manager shoulddisappear. You may need to reboot for the changes to take effect.
Trendnet TU3H4 USB3.0 Hub does not work in windows 8. Device manager says it is (not functional)
HelloI have the same problem!I have a message to the support
https://www.trendnet.com/asp/helpdesk/
Kind regards
1helpful
Acer aspire usb root hub driver
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Sxuptp driver (belkin hub) makes XP PC hang with start up PC
I tried many procedures to get this working in Win7 x64 but every time I ran the installation package for the Belkin control center Windows stopped the process and showed there was and error with the Setup64.exe
Then I decided to go to the Silex web site and found a recent version of the Virtual Link software, which is the software the Belking control center is based on. Downloaded it, installed it (with no Belkin crapware installed whatsoever, remove everything Belkin first) and it runs 100%. I can see my printer with no issues. biggrin.gif party.gif
The link to the software page is this >>> http://www.silexamerica.com/support/software/svl.html
They have fairly updated versions for Win and Mac. I hope this helps.
1helpful
2answers
Usb device not recognized, works only when plugged on hub
All PCs provides power supply via USB port. The power is controlled by electronic circuit. Sometimes when overloaded the circuit burns out (the last controlling transistor, actually). This does not prevent the data communication, because it is separated circuit. But if the device is not powered it cannot communicate. When you plug the USB device to powered USB hub, then all go right.
Are you able to use the USB ports with other USB-powered devices like USB sticks, mouses, cameras? If not, the mentioned circuit is burned out. If they work OK, then your internal USB hub provides less power current than needed. In both cases there is nothing to do. The circuit resides on the mainboard of the laptop and replacement is expencive. Use it with that external USB hub you have.
USB HUB, Receiver & Keyboard
dude
Try to update windows xp service pack, i guess usb root hub drivers is missing, when you updated windows xp they will get fixed by itself
Top Belkin Components Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Belkin Components Computer and Internet Expert? Answer questions, earn points and help others
