I just recently got the projector from someone and when I power on, no color or images are projected. On the panel, the power button light is on as a solid red color; also, the temp/fan light is flashing red. Help.
SOURCE: Does not display the color blue?
lamp replacement will not solve your problem. The problem is with the main board or RGB Panels.
Viren
SOURCE: Yamaha LPX 510
Well let me add to that, I had the same issue & they did the same thing 1 year ago and guess what I just noticed "YEP" Blue tint on the upper right corner. When I had it fixed the picture was even better than when I purchased it but it happened again. I hope they warranty the unit om the date it was fixed.
SOURCE: yamaha LPX 500 home cinema projector isn't lighting up
The reason for a red light is replacement of lamp or it is running too hot. Have you checked for proper venting, and cleaned them recently. The bulb usually lasts 2000 hours, so you may need another.
SOURCE: My YAMAHA LPX-500 projectors start up logo remains
Hello sounds like you have the logo screen burned into one of your LCD panels. This will be a very expensive repair, seen as the LPX-500 is only an 800 lumen projector, it would be a good time to look for a replacement. I would not recommend spending any money on this unit.
Hope this helps
Projector Guy
