Question about LG 42LG50 42 in. LCD HDTV
I have a 32inch lg cs46 series tv and the system lock has been activated mistakenly and it askes for password when i try to ***** the set up and retune my tv,is there any master code i can use?
I have a 32inch lg cs46 series tv and the system lock has been activated mistakenly and it askes for password when i try to asess the set up and retune my tv,is there any master code i can use?
4 Suggested Answers
6ya staff
SOURCE:
dsg280
SOURCE: dont the know the code to unlock my lg tv
Try 7777 as the passcode
Posted on Sep 30, 2009
Testimonial: "yes its worked thank you very much appreciate it."
lovebug1028
  • 47 Answers
SOURCE: I need to retune my LG 32ld450 TV, but the
try 0000
Posted on May 07, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: hi my LG LCD TV 32LK450 is now asking a password for it to be cable ready, i have not created any password before and i am sure no one has ever tried placing a password on the TV. i have tried common
Have a good read of the owner manual as answer should be there or take the time with the model number and CALL LG customer service and have them step you thru the unlock process.
I bet it is covered in the owner manual.
Posted on Apr 12, 2012
My Lg tv #37lh260h keeps showing Input blocked .It wants password and I never set 1 .Help Im so frustrated
Hello Lisa,
Try using the default password 0000 or if that doesn't work, go to menu, lock and see if the lock system is on.. If the lock system is on, turn it off.
Check the TV user's guide for more info.
Hope this works
Apr 12, 2018 | LG Televison & Video
Was playing radio on lg smart tv , now we have a musical note floating on every channel , not sure how to get rid of it have tried on /off . Reboot as well
Not sure what you've selected but most lg smart TVs have an initial setting under the options menu that performs a factory reset. It will restart on its own when it's done. If you have set a password and the lock is active a pop up will ask you for it as this is not reset and so if you don't know it then don't reset the TV else you'll be locked out. Also very important is to not power off the set while it's re-initialising either.
Jul 17, 2017 | LG Televison & Video
default codes are normally 0000 or 1234. if you need more numbers for code continue sequence, but 4 numbers is the norm. Hope this helps
Dec 28, 2015 | LG Cell Phones
How do i reset lg 5700 t.v. can't get past the lock forgot password?
I'd try the reset first. You could try asking their support. They seem to answer every question that they are asked, and the answers seem pretty thorough.
Product Support
Jan 01, 2015 | LG 42" 5700 Series LED HDTV - 42LN5700
Im trying to turn off audio description but cannot find the SAP.Model number LS35 / LS34/ CS46 These numbers are listed on the front of the manual..Thankyou
If it is from programs you have recorded, you need to change the settings on your PVR, not the TV. Each PVR is different so you'll need to check the owners manual for your model.
Oct 18, 2014 | LG Televison & Video
Password reset TV LG 60LA620S
You say it doesn't ask for code whats that mean, is the tv still locked? If You can get into the menu, do a factory reset!
Jul 07, 2017 | LG Televison & Video
How to reset LGTv password
Which LG TV do you have? For the LG TV that I have, you need to know the current password to change it or return it to the default.
For my unit, click the Menu button on the remote. Go to Settings and click Enter. Navigate to Lock and click enter. Then select Set Password and click enter again. The default (initial) password is 0000 . Click Enter again to save the password. To enable or disable the Lock, select System Lock from the Lock sub-menu. You will need to enter the password to unlock the TV.
I hope this helps. (My tv is a recent Smart TV 3D units.) Please add a comment with your model and I'll try to check if there are other steps you can try. My TV remembers the password even when unplugged since it has solid state memory.
Nov 08, 2012 | Televison & Video
How to reset a password
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
Sep 17, 2011 | LG 42LG50 42 in. LCD HDTV
My ELCOT TV ask password, TV screen showing Limit Set, Limit Lock ON ask Password.
May 10, 2011 | Televison & Video
Vision Quest 32inch PVQ-32VGB password not working... locked out
Hi jcbd,
Did you get any solution so far?
I encounter the same probleme with my TV now
Please let me know what you did,
Thanks
By jcbd on Mar 10, 2010
I have a Vision Quest 32inch PVQ-32VGB and the some of the channels have locked and the factory password of 0000 does not work any suggestions? thanks
Mar 10, 2010 | Televison & Video
LG 42LG50 42 in. LCD HDTV Logo
48 people viewed this question
Ekse
RONALD CARTER JR
