General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
A
Anonymous Posted on Nov 06, 2013
Old Eaton's Viking 24 inch stove timer making noise
I need to replace the elements in my old Eaton Viking stove from the 70's or 80's but I can't find the specs.
I have an early 70s GE stove that looks like that era Vikings. They are pretty much the same wattage, if I remember oven is 2,500 watts. You buy them by shape. You need the model number, it will be at the rear on a stamped metal tag.
I just take the old one to Canadian Tire and pick them off the shelf for about $36.00 CDN. Stove TOP, Stove Oven? Viking sell parts.
https://www.allvikingparts.com/PJ010004_BAKE_ELEMENT_p/pj010004.htm
Or pick by the images. The stove top elements are just in two sizes. Given the model number and the element you need, I bet I could find them.
https://www.google.com/search?q=eaton+viking+stove+elements&sca_esv=594661664&rlz=1C1QJDB_enCA643CA644&tbm=isch&sxsrf=AM9HkKlr1Ku7omqszJ4KH0QuOR20gYnwYQ:1703985066791&source=lnms&sa=X&ved=2ahUKEwiH7O6Ev7iDAxUEEVkFHaxMCs8Q_AUoAnoECAEQBA&biw=1920&bih=919&dpr=1
1helpful
Where can II get a replacement 11 in by 16 in oven bake element with 9 inch contacts for my eaton viking model 305 vin
There are several options for obtaining a replacement oven bake element for your 11-inch by 16-inch Eaton Viking 305 Wine model with 9-inch contacts. Here are some of the options you can try:
Check if the manufacturer Eaton Viking offers a replacement element compatible with your oven model. You can check their website or contact their customer service for help.
Look online for spare parts stores for appliances. You can search online or local stores that sell oven bakeware for your oven model. Some popular online stores include Amazon, eBay, or appliance parts sites.
Contact an oven technician or servicer for assistance. A qualified technician may be able to help you find the correct replacement oven bake element for your Eaton Viking 305 Wine model.
Look for online forums or groups for appliance owners. There are online groups where homeowners discuss their experiences repairing and maintaining their appliances. You can join these groups and ask questions for help and advice on finding a replacement oven bake element for your Eaton Viking 305 Wine model.
It is important to note that you may need to provide the exact model number of your Eaton Viking oven when searching for a replacement part to ensure you get the correct part for your appliance.
Eaton viking wiring - how to update ?
call a local electrician to do the task . if not done properly you might have a fire or worse yet get someone killed by a short thru their body
I have a eaton viking stove from 1987 . I NEED a video on wiring repair.
Unlikely you will find a video on a stove that old. The wiring schematic is on the back of mine. You might also find it in the control unit at the top.
You don't say what the wiring repair is, but I have replaced elements in the oven, both the bottom one and the broiler, and I have also replaced the top burners and the connectors to them. I have an early 70s GE. We keep saying we will replace it when it goes wrong, but it never has since.
https://www.google.com/search?q=eaton+viking+stove+from+1987+wiring+schematic
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
Eaton viking stove
You can date most of your major home appliances from the US and Canada at the following link.
Appliance411 Service How old is my appliance Age finder date of...
2helpful
3answers
How do you set the analog clock?
My eaton viking imperial stove came with the house and no manuals. The timers are digial, how do i set them
1helpful
Stove oven wont work..
Yes, you can use the Eaton Viking element in place of the Gibson element as long as all mountings are the same.
You should use ceramic washers between the element and the casing to prevent it from grounding out...which is what probably happened to the element in the first place.
Be sure to look for chapped or burnt wiring BEFORE replacing the element. Also look for burnt connectors.
Hope this help you! :)
26helpful
4answers
Old Eaton Viking Stove - broil won't turn off.
I have the same stove, and just had the same problem. I looked all over the internet to try to find an answer, and then went back to my stove to check the serial number and where the fuses are was the instructions printed on the stove itself.
SO HERE'S THE SOLUTION
1. The timer start knob (the one with little running guy picture) must NOT be pushed in. If it is, turn it slowly until it snaps out.
2. The timer stop knob (the one with the picture of the stop sign) must be completely pushed in.
I hope that helps everyone out!
Top General Electric Hardware & Accessories Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
