SOURCE: i have a lg dishwasher ld-14aw1over flow
On an LG LD-14AW1, three is a float sensor on the left hand side of the dishwasher, behing the water outlet port.
It is the sensor that tells the dishwasher to stop filling just before the wash or rinse cycle begins.
A service call is needed or post back here is you want help replacing it.
SOURCE: Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
SOURCE: my LG model LD-12AS1 dishwasher will not drain, please help
Hi
Thanks for using FixYa.
Dishwasher not draining properly or not draining at all issues can arise due
to different reasons. Usually, these issues are related to kinked hoses,
knocked out disposer unit (if connected with the dishwasher drain hose) &
clogged drain pump & filter.
Also note that dishwashers do not
drain completely after a finished cycle and this is normal. Dishwashers are
designed to leave some water in the unit to ensure that the heating element
doesn’t overheat. If you suddenly begin to experience a large amount of water
being retained in your dishwasher, you have a problem. Some of the most common
reasons include that the drain hose isn’t working properly, the drain pump
isn’t working correctly, or possibly there is a plumbing problem in your home’s
drain lines.
First check whether the drain is
not clogged or blocked and the line is not kinked. Check all the hoses for
blockages & also clean the air gap. Has the disposer been replaced
recently? If so, chances are the knockout is still in place. Simply remove the
drain hose from the disposer, and knock out the plug. If the disposer has not
been replaced, try removing the drain hose from the disposer and use a wet-dry
vacuum (prepared for water, of course) to **** any water (and hopefully anything
else) from the drain line. Then reconnect the hose, and test the unit. If you
have checked the air gap and the drain hose and can’t locate the problem, then
it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
Testimonial: "well done"
SOURCE: LG Dishwasher LD-2050WH with HE error code
LG Told me the water coming in was to hot and to disconnect power for a few seconds and reset water heater to around 120 deg
SOURCE: Bought a LG LD 05AW2 benchtop dishwasher second
More than likely it is the electronic control board.
The main water pump on this model does not last long. The water seal between pump and motor starts to leak that result in the adjacent motor bearing corroding and eventually failing, resulting in excessive noise. Later the water leak becomes so bad that it triggers the "E I" water leakage display and prevents it from completing the program. The pump and motor is sold as one unit and the whole unit must be replaced. I have tried to replace the faulty bearing and repacked the rubber seal with silicon grease but with no success. If anyone have repaired the water seal successfully please let us know.
