When we turn on our machine the bulb comes on briefly like a flash but won't stay on. We have tried to reset the machine but it still does the same thing, we don't think its the bulb since it briefly lights up for about 1 sec. machine sounds like it is running fine bulb just won't stay lit.
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
SOURCE: flasing red light
power light green the lamp light flashes green for awhile then goes red. Replaced the bulb same problem.
I unplugged it then held the power button on and plugged the power cord back in. it started working correctly, and shuts off and on ok now.
SOURCE: flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
SOURCE: XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
SOURCE: I have a Sharp projector model# XV-Z10000. The
you didn't reset the lamp timer. hold down the down arrow, right arrow, and enter buttons, then press power on.
