Question about Gemini PT-1000 II Turntable
Using serato the playback is slow
4 Suggested Answers
6ya staff
SOURCE:
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: How to remove the platter in Gemini PT-2400
hi,
firs of all remove from the mains. pull out the rubber bed over the platter. check whether there is any lock washer in the center shaft. if have remove it. if not its ok. now pull the platter towards upside by putting the fingers in to the holes provided on the platter. remember pull using ur two hands in opposite direction.
ok
Posted on Dec 30, 2010
Grubhead
Grubhead
  • 5699 Answers
SOURCE: i plugged my gemini pt-1000 turntable into the aux
If the amp doesn't have an imput marked phono, or deck, or turntable, the answer is yes. Search for a 'magnetic cartridge pre-amp' via google.
Posted on Feb 28, 2011
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
Turntable spinning to fast
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself.
For the manual visit the Gemini website.
Apr 21, 2013 | Gemini PT-1000 II Turntable
Direct drive spinning to fast
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
Belt speed slow
The belt could be stretched and slipping on the motor shaft
Nov 17, 2012 | Gemini PT-1000 II Turntable
I need to replace the needle and am not sure which option or model is or are compatable. Have you a suggestion preferably a model #/ brand? Thanks!
There should be a number on the cartridge, put that into google and that should answer your question. If you need a cartridge you can generally use any that will fit the headshell, as long it is a magnetic cartridge. It will depend on how much you want to spend for the best quality.
Jun 25, 2011 | Gemini PT-1000 II Turntable
I plugged my gemini pt-1000 turntable into the aux in the back of my stereo, but the sound is very low. Do I need a preamp?
Feb 26, 2011 | Gemini PT-1000 II Turntable
Turntable will not hold pitch,speeds up or slows down.
try replacing the drive belt with brand new one and see if this improves the situation
May 27, 2009 | Philips gemini XL-500 II Turntable
Missing clip
Parts for that turntable are nearly impossible to find. As far as I know, Pacific Parts is the only place that stocks these kind of parts.
Apr 07, 2009 | Audio Players & Recorders
Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
Apr 11, 2008 | Gemini PT-1000 II Turntable
Gemini PT-1000 II Turntable Logo
65 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Vernon Taylor
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
