Key won't turn all the way to open and don't remember the combination
Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
What is the Manufacturers combination numbers. We happened to lock the book and important papers in our safe and someone had turned the dial when we were moving the safe and now we don't know what the combination is when we bought the safe.
I did the same thing you did with our safe. Did you ever get it opened...what did you have to do?
I have the key but never set up a combination and the combination knob was turned by mistake and now we can't open it. The Manual is in the safe!
I have a brinks security home safe but lost my keys to it & now want to know how to replace lock& key jeanne 314 537-1153
SOURCE: brinks fire resistant safe model 5059 instruction manual
Brinks Manual UP date update ,
Dismentaled my Brinks unti , 5059.
I have taken off all moving Parts of my safe.
all are in working order, i also took 2 minute video of the dismantling of unit, i have the combonation & two keys and owners manual.... My Loss is your gain...
face- plate- screws. everything
sn # 3251. [email protected]
To bad you dismantled. Here is the turning sequence:
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
