Kingston 4GB Secure Digital High Capacity Memory Card Logo
A
Anonymous Posted on Nov 05, 2013
Windows has stopped this device because it has reported problems code 43
2 Related Answers
Anonymous
  • 542 Answers
  • Posted on Dec 14, 2009
SOURCE: problem with 4gb dti pen drive
Try to format the pen drive may solve your problem. Also chkdsk command to solve most of the problems.
jdavies255
TechRx Inc http://techrxgb.com
  • 331 Answers
  • Posted on Nov 05, 2010
SOURCE: Windows has stopped this device because it has
This is a sign that the controller on the chip is gone bad. You may need to send it to a data recovery company like TechRx, Inc. if you need to save your data. Otherwise, toss it and use a new card. Thumbdrives have embedded controllers. These last "only so long" and then the cards go bad.
Windows has stopped this device because it has reported problems. (Code 43) epson printer CX9300F
Make sure you are using the correct driver for your operating system. You can download drivers for Windows 7 32-bit and 64-bit here:
Epson Stylus CX9300F Drivers Software
Note that this is a non-US-based website. Make sure that the language of your version of Windows 7 and the Epson driver you install are the same.
Panasonic kx f612 code 43 error
Windows has stopped this device because it has reported problems (Code 43).
Code 43 can be summarized in two words: driver problem.
I can't help you any more without knowing which Windows version you are using, but the Panasonic website is
http://panasonic.net/pcc/support/bfax/
I cannot cannect my 6230i nokia to my computer when connected your device is reported windows error 43
Error Code 43 is a Device Manager error that means the following:
When you get this error with USB devices it's because one of the drivers controlling the device notified the operating system that the device failed in some manner. It will be of issue of the loaded corrupted drivers. You should reinstall the operating system or reinstall the drivers that doesnt have virus or file damages.
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
2answers
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Windows has stopped this device because it has reported problems. Code 43
Code 43 is triggered when the device stops responding completely. So if it hasn't been disconnected it means that it has failed at a hardware level - it has died. Sorry, this is terminal, time for a new one.
Whats code 43? i have an HTC Touch phone im
As Microsoft states.
Recommended resolution
One of the drivers controlling the device notified the operating system that the device failed in some manner.
If you have already run the Troubleshooting Wizard, you might want to check the hardware documentation for more information about diagnosing the problem.
1helpful
2answers
Cannot synchronize my phone, showing error code 43
Code 43 Windows has stopped this device because it has reported problems. (Code 43) Recommended resolution
Try reinstalling the ActiveSync Software.
I've installed a darfon bluetooth radio into my hp compaq 6715B laptop. I've also reinstalled the integrated wireless utility thing. Its not working, device manager states "windows had to disable the...
Code 43 Windows has stopped this device because it has reported problems. (Code 43)Recommended resolution
One of the drivers controlling the device notified the operating system that the device failed in some manner. For more information about how to diagnose the problem, see the hardware documentation.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
