Question about Magic Chef 31000 Gas Kitchen Range
Oven will shut on and off constantly
The hot surface igniters are working fine
    New Friend:
  • 15 Answers
Sometimes the hot surface ignitors are fine, but they do not have enough draw to start the gas valve. If the oven doesn't light I would replace those first
Posted on Jan 17, 2014
Anonymous
SOURCE:
Gas oven doesn't work
Sounds like it could be a bad Hot Surface Igniter, Check to see if you see glowing, if not, have the Igniter replaced.
Dec 05, 2013 | Tappan Ovens
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Apparently, the range works fine but the oven fails to fire; my friends son in law has this problem and I have been asked to discover why.....I am believing that the ignitor is the possible problem, any...
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on and the igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. You can also verify that the oven run-away valve is not closed. This valve will be located at the back bottom of the range at the gas regulator. There will be a tab on the regulator housing where the gas pipe goes to the oven. This tab will lift up to close gas flow to the oven. Sometimes these valves can stick causing the oven to stop working. You can try moving this tab back and forth to see if it loosens any debris in the valve. Move the valve while the oven is on and you will be able to hear the burner come on after moving the valve if that was the problem.
May 08, 2010 | Amana ACS3350AS Gas Kitchen Range
Oven will not heat
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Apr 01, 2010 | Tappan TGF363 Gas Kitchen Range
My gas oven will not heat up, stove top turns on, but oven will not turn on.
First you will need to verify if the hot surface igniter is coming on when the oven thermostat is in demand. When the thermostat is turned on for the oven you should see the igniter start to glow. You may need to remove the bottom oven panel to be able to see it in action. If it starts to glow then take a wrench and tap the gas control valve located at the back of the oven in the broiler/storage compartment on the bottom of the range. If you tap the valve and the burner comes on then shut off the oven completely and back on several times and make sure it is working. If it does you may have solved the problem. If the burner does not come back on and you have to tap it again then the gas valve is sticking either due to a bad valve or weak igniter. If the igniter does not glow then the igniter could be bad. You would need to verify the igniter is getting voltage. Then the igniter can be tested with a ohm meter. A good reading usually is between 500 to 700 ohms. The hot surface igniter cang get a crack in it causing it to stop working.
Nov 03, 2009 | Whirlpool GW395 Gas Kitchen Range
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
Pilot Light Wont Light
Take off the top cover plate inside the oven. Now with the door open turn the oven on does the hot surface glow? If it doesn't glow then you have a bad igniter and needs to be replaced. What ever you do don't touch the surface of the new igniter human oil will shorten the life of the igniter. now if the hot surface glows then the gas valve is bad and need to be replaced. I'm betting it's the hot surface.
Nov 25, 2008 | Amana Ovens
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Magic Chef 31000 Gas Kitchen Range Logo
81 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
