Most likely, your yellow ink nozzles are clogged. Some printers include the print head with the ink carts, but some do not. Epson and Canon are examples of printers that do not come with new print heads with ink. They have the ability to clean the print head if it becomes clogged. What printer do you have?
Most likely the cyan ink is burnt. If the ink sticks are left unused (printing more black than color, this will happen.
Print the test pages for PQ troubleshooting from the control panel and examine each print. Cyan will probably have very dark streaks down the page, magenta should look normal, and yellow also will have dark stripes. You need to replace this burnt ink, and the only way is to print. From within paint (or similar accessory in other OS) Create a full page of cyan, and print about 100 - 200 pages, or until the cyan starts to clear up. Yes it is a waste, but much cheaper than a print head, Do this for yellow as well.
Often "grayscale" is achieved by mixing some of your colors (CYM) to form composite black and gray - not necessarily just black from your black cartridge. Often there is some yellow used beneath the black -- so if you are getting a red or blue tint, it could mean something as simple as being low on yellow ink.
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
