Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Whilst charging one red light on makita charger
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Charging steady red then flashing red overheating and green red flashing replace battery.
Posted on Nov 06, 2013
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Posted on May 23, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: hi i have a makita charger that flashes red and
there is a problem with the charger and given the age I would take it to an authorized dealer and get a replacement. If you give me your general area I will try and locate one close to you. Please before voting if you need more assistance let me know. Thank you
Posted on Feb 02, 2011
Dave Taschuk
  • 4 Answers
SOURCE: Makita 18v lithium battery when put on charge
This isn't true because I have a second charger and it works fine
Posted on Nov 19, 2011
Red light flashing will not charge battery have left over night with no result
Sometimes, this is a result of a battery that is too cold (below freezing-warm it up). Sometimes it can be too hot (discharged under heavy stress-let it cool down). Sometimes there may be insufficient voltage, I have had problems in older houses, get closer to the electrical panel to plug in, or you may have to wait until you get home. Red flashing may mean https://www.youtube.com/watch?v=8rZqYmPsZycthe charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been dropped or hit the floor the coil inside could have broke loose and damaged the charger requiring it to be replaced. Below is an unconventional way to charge the battery if the charger is no good. BE CAREFUL
how to charge broken makita BL1830 Li ion battery
Mar 12, 2015 | Makita Cc300dz 10.8V Li-Ion Cordless Tile...
Makita bl1830 charges but stays on static red light
Chargers have been known to lie about what they are indicating. Even though you say the batteries were charged only a hanful of times, they may, in fact, have expired
Apr 03, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
Mar 17, 2012 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Hi, My Makita DC18RA won't charge anything it just flashers the red and green light simultaneously it is not the batteries because I can charge them fine using anther charger. What is wrong with the...
none of these answers help. you cant return old chargers to the store, and the poster said his battery charged on a different charger. i have the same problem with 2 makita battery chargers and need to know if there is a part inside the charger that can be replaced.
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
Apr 18, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Need to know what the lights mean on a makita dc24sa charger
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
Nov 20, 2008 | Makita DC24SA 24 Volt Makstar Battery...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
407 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
