My becket honeywell r7184p oil burner monitor is not resetting it keeps blinking a fast green. What should i be looking for?
my Beckett oil burner with a honeywell R7184P just did the same thing. Quit burning, blinks for half a second. The burner says press reset once, if it does not reset then call a local serviceman. It is cold here in Alaska, you betcha', and my oil must have jelled up. It happened once, but pressing reset solved my problem, two days later it stopped again. I applied heat (hair dryer) to my supply line, added an anti-jelling solution to my tank. Here is what I found.
"The Honeywell R7184P-1080 (interrupted control—transformer shuts down 10 seconds after flame is established) is now the standard control used on all Beckett oil burners along with the new “Cleancut” pump. The Honeywell control has both a 15 second pre-purge and a 15 second post purge feature, as well as internal self-checking of the control itself. The control has 15 second lockout timing plus a 10 second ignition carry over period. After 3 lockouts during the same call for heat, the control goes into restricted lockout., A restricted lockout condition may be reset by holding the reset button down for 30 seconds until the LED flashes twice. At any time the control is powered, the reset button may be held for 30 seconds to reset the lockout counter. There are several new “Service Features” with the R7184P control that make for easier servicing."
You have to press the reset button for thirty seconds. I don't know how cold it it there, or what number oil you guys are burning, but what I do know is that you guys have been pressing your reset button more than once.
This worked for me. Good luck.
