Question about Maytag Stackable Washer Dryer
MAYTAG STACKABLE WASHER DRYER MODEL LSE7804ACE FILLS WITH WATER ONLY
WASHER ONLY FILLS WITH WATER, DOES NOT WORK IN ANY CYCLE,, DRYER WORKS FINE
    New Friend:
  • 33 Answers
I would check the lid switch 1st
Posted on Nov 05, 2013
  • Dana Taylor Apr 28, 2017
    https://www.google.ca/search?q=Wiring+di...
    Here are the wiring diagram
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 65 Answers
SOURCE: Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Posted on Jan 26, 2009
scott
  • 532 Answers
SOURCE: Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
Posted on May 10, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Posted on Sep 29, 2009
My stackable maytag lse7804ace washer will not drain after agitation. The dial sticks and begins to hum.
As with most appliances and cars wiring harness are made to service many models for economy to the manufacture. One harness may have 50 wires in it but your washer may only use 30 of those wires. A wiring diagram is a must. If it did not come in the paper work that came with the washer you should be able to find it online. The last 2 washes I worked on had away to put them into a self diagnostic mode this may also be in your manuel. In both cases they had a no drain problem as the code stated and gave me a place to start and because of the way washers are made now adays the drain water pump gets clogged after so many seconds of not pumping it will shut the washer down. I guess to keep the motor from burning out. Taking the water pump assembly apart I found a sock yes a sock wrap around the impellers and this was in both washers. Removed the socks reassemble and both washers worked like new. this site might help you too. http://www.partselect.com/Models/LSE7804ACE/#Symptoms.
I have a Maytag refrigerator never again from day one one problem after another. The Maytag of yesterday is no more.
Jun 14, 2014 | Maytag Performa PAV2200
MAYTAG STACKABLE WASHER FILLS BUT NOTHING ELSE
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
Nov 05, 2013 | Maytag Stackable Washer Dryer
I have a Maytag lsg7804aae stackable unit. The problem I am having is that the washer will not agitate or fill with water, however the unit will work on the spin cycle in all modes. Opened front panel of...
timer is good, if you tried it on all the different cycles, must be the water inlet valve, does the hot water work, if you set to warm or hot..if so the cold water valve is shot
Dec 19, 2010 | Maytag LSE7806A Top Load Stacked...
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Stackable Washer Dryer Logo
323 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
