Fossil BQ9184 Wrist Watch Logo
A
Anonymous Posted on Nov 04, 2013
Fossil bq9184 how to replacve battery on bq9184 watch
5 Related Answers
riflemenx
  • Posted on Jun 19, 2008
SOURCE: Fossil ES1592
watch press
Anonymous
  • Posted on Nov 09, 2008
SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Anonymous
  • Posted on Dec 24, 2008
SOURCE: Changing the battery for my Fossil Watch
You have to have a tool to unscrew the back of the watch. I figured this out the hard way. I suggest taking it to a jewler for after I replaced my battery, the stinking thing still did not work. This sounds like a commom problem as I read more about them. Hope this helped.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 26, 2009
SOURCE: Fossil watch dead
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
Anonymous
  • 2501 Answers
  • Posted on Jan 16, 2011
SOURCE: How do I set my Fossil watch? It has three dials
Fossil do not have a list of instructions under model numbers but issue a list of generic instructions which you have to wade through to find the one that suits your watch.
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and put your cursor over each of the ones listed in the Multifunction section until you reach the one that looks nearest yours and download the file.
6helpful
2answers
How do I set my Fossil watch? It has three dials on the face (looks like one for day of week, one for day of month (goes to 31) and one for seconds). Has only one pin on right side. Says !)ATM on face....
I lost my battery for my fossil watch. how do I find the correct battery number to put in the watch?
Go to your nearest "Batteries Plus" store, they have just about every battery under the sun and they'll install it for you FREE
I have found a fossil watch model BG-2103. I cannot get the back off to change the battery, can you tell me how to get the back off and how much this watch cost.
mcdevito75 here, Look for any Notch in the cover that match a notch in the case, use a knife with a sharp blade and place the knife in the notch and with a slight twisting motion the cover should pop off. Depending on the age of the watch and the functions cost could be anywhere betwwen $25.00----$60.00 Fossil watches are also collectables.
2answers
I have lost the battery for my Fossil Blue BQ 9039 watch. What battery number should I get to replace it?
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
MY WATCH JUST STOP WORKING
first u have to check the batteries whether it is in good condition or not,if the batteries in good condition then go for the movements check
Fossil blue collection wrist watch, services in hyderabad and cost
You are now way NEAR a center. You will have to go to Fossil.com and find one in a nearby country.
Cant get back off
You need a very thin knife but I would not suggest you do it yourself. Remember, as hard as it is to get off, it is almost as hard to get back on. Fossil watches are tough to change the battery for, you also have to be careful of the crystal, they break easily.
I would suggest you just take it to a jeweler and pay the $6-$10. for them to do it.
Hope this helps.
Steven
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
