I have a Sylvania LC320SL1, and when I play certain DVD movies and some blu-ray movies (from my Sony NSZ-GT1), using a HDMI connection, the audio cuts out several times every few seconds. I believe it is the TV, because I tried connecting my blu-ray player to another screen using the same HDMI cable, and the audio did not have any problems.
SOURCE: 42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
SOURCE: When trying to connect my 4695D to a new Sony Blu
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
SOURCE: My HDMI connection does not work with Blu Ray DVD
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
SOURCE: I have just about given
Please exchange HDMI cable, use any other HDMI cable in BluRay and TV and I would recommend to plug cable in another HDMI port in tv (if available) to solve this issue.
Make sure HDMI cable connector is plugged fully in both units, lose connection can cause No Signal display in tv any time.
Hope these info will help you.
Thanks.
SOURCE: i connected a samsung home
You need to connect the "Audio/Digital Audio Out" of the TV or Cable box to the "Audio Input" of your home theater receiver.
