HI:
I have recharge the batteries in my camera through the AC adapter for the camera. The batteries are rechargable but I have lost the charger for the batteries.
THanks,
MH
The A430 is a camera, not a battery charger. If you want to use rechargeable batteries then you must use a separate charger. Battery chargers should be available at just about any department, electronics, or office-supply store.
SOURCE: My canon EOS 450D battery loses power within 5mins
If it's an original battery, call Canon, if you've only charged it once, I expect the camera is still under warranty. I've had lots of dealings with Canon Photography, the usually give extremely good customer service.
If it's a cheap one you bought of ebay - that's why!
www.yourhandinmine.co.uk
SOURCE: My Canon Powershot A430 will not accept new
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
SOURCE: Canon Powershot A470 - asks to 'change battery'
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
SOURCE: Canon powershot will not power on
Hello. If you mention the exact powershot model,I may be able to provide better help. Since I don't know your model, I can tell you to go to: www.camerasandparts.com since they specialize in service for the canon powershot digital cameras only. They're amazing if you need help with one of these and they have the no power fix for every powershot right there on their site. I hope that helps, that's the place if you need help with a canon. Good luck with it.
SOURCE: my canon powershot sd 1200 wont turn on.
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
